Displays whether the user configured a username and password for the failsafe account or shows the configured connection type access restrictions.
N/A.
Use this command to view the failsafe account configuration.
The command shows the access permissions and whether or not the user configured a username and password. It does not show the configured username or password.
The following command displays the failsafe account configuration:
show failsafe-account
Output from this command looks similar to the following when a failsafe account username and password have been configured with all connections types permitted for failsafe account access:
The Failsafe Account is enabled for these connection types:
- Serial Console
- Control Fabric (inter-node)
The Failsafe Account is disabled.
This command was first available in ExtremeXOS 12.0.
